PC power supply, Please Help | Page 3 | on ElectriciansForums
Discuss PC power supply, Please Help in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hello,
My PC Power Supply Unit came fitted with a 13A fuse in the power cable. When i just turned my pc on it blown the fuse and now its completely dead. I took the Power Supply Unit out and checked the label and it says:
Input Current 10A – 5A
I did not realise this as i thought the cable that came with the unit would just work straight out the box! My question is, do i use a 10A fuse or 5A?? and would they be safe to plug in a power strip?
Thank you!
power strip? like this?
[ElectriciansForums.net] PC power supply, Please Help
Never tried as my wall socket is hard to get to so I use a power strip
We're trying to help you by process of elimination. Take the "power strip" out of the equation and see what happens. Also forget about 5A and 10A fuses, this is a red herring (and outside of the scope of ISITEE, which only recognises 3A and 13A fuses). Plug it into any other 13A wall socket!
Can a 5A or 10A fused be used? I don't think it's the cable getting old as this was replaced when the PSU got replaced. Could it be my surge protected power strip? Is it OK to plug a 13A plug into a power strip? When I flick the switch on the power strip, nothing else is turned on as I always turn my PC on first then my monitor
The fuse size wont cause the issue you're having, be it 5, 10 or 13Amp you'll get the same result with all of them.
Something is causing the fuse to blow, if it's blowing instantly then its pulling somewhere around 40-60Amps or more of fault current at a rough guess, so to me (and I'm by no means an expert, so take this as you will) it sounds like you have a short somewhere.
i dont have a PSU atm as its completely dead, i'll try tomorrow when i get a replacement.
Use whatever you like but a 13A is fine. You seem to be getting hung up on fuse sizes.
Only 2 sizes are needed. 3 and 13.
If a 13 is popping even after changing the cord it’s time for a new one of whatever is on the end of it. PC, PSU or a banana bending machine.
If its possible to safely power up the PSU before you put it in the computer , I would do that at the very least...If this one then pops, you know the problem is further back, possibly in the extension lead..
If its fine out of the PC, fit it back in and try again...
Expensive way to fault things though!
10-5A refers to the absolute maximum the PSU can consume at 120V to 230V respectively, i.e. 5A at 230V. It has nothing to do with the plug fuse size. Any of 5A, 10A, 13A fuses should be OK - the PSU has internal protection against overload - but the inrush on large PSUs can fatigue a 5A fuse after time. They are designed to be protected at 16A in Europe where protection is in the DB not in the plug fuse.
If a desktop computer PSU blows a 13A fuse it is faulty, end of. A typical desktop draws 1-2A on 230V maybe even less than 1A. Only if you have multiple super duper graphics cards all mining crypto would you need 1500W as mentioned above.
Power strip in Pink ..original..!
Classic causes for big bang ...a) Include Flicking that little 120/240 selector switch on older " Models"!
..b) They often die in a spectacular bang ,if cheap (large Black Label) No internal fuse !
( My Unsee is not working today)
Middle size 5A would be a DIY Home owner answer !
(under 10A stated on Euro plug)
99% chance , need a new power-supply/ case with free one !
-Unless cable has been damaged /trapped ...-Throw them both !
As above, most decent ATX Power supply units are protected by an internal T5A or T6.3A fuse but there are exceptions with some unbranded models!
The voltage selection switch if in the 110/120V position usually results in a loud bang followed by plumes of white acrid smoke as the smoothing capacitors rated at 200VDC are suddenly provided with 400VDC then overheat and vent.
There was also a problem with some supplied mains leads a while ago where both the outer insulation and conductor insulation cracked when flexed and also faulty molded plugs.
Buy a decent branded ATX PSU and try that.
If the 13A fuse is blowing, changing to a 5A or 3A will not help, they will just blow.
I am wondering whether you have installed any new cards in the pc, especially graphic cards?
If that is not the case, then you may have a siezed hard drive.
Reply to PC power supply, Please Help in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
