I have been told I can power leds from my old PC PSU as a cost effective way of using my old unused computer. I need advice on what I can drive with them.
I want to use 10w square LEDs which require 10-12v DC and 1050mA each. I am aware that most of the outputs are 12v from the PSU. Does this mean I can only run 1 LED per output wire, or is there a way that I can run multiple of the same string.
The reason I ask is that I need to have about 6 LEDs on a string and put a time switch and a dimmer in line before them to control the set of 6.
Any help would be great. Thanks.
