pdf version of the regs | Page 4 | on ElectriciansForums
Discuss pdf version of the regs in the UK Electrical Forum area at ElectriciansForums.net
banny07
Hi Guys. Is it acceptable to have pdf version of regs to show niceic assesment day? Thanks
The text and tables aren't processed, they are an image. The hidden layer of text is processed, but as above, you don't see that unless you select something by click and drag. I'll try to upload a photo so you can see what I mean.
I know what you mean. But that may not be the case in the OPs version. There have been counterfeit copies with errors in before.
I must admit that when I get the regs book from work, I take mine apart and scan it, then OCR it, so that I can search for text.
It does make things easy for me.
No.... I don't pass it onto anyone.
Reply to pdf version of the regs in the UK Electrical Forum area at ElectriciansForums.net
If it's underground I've always favoured SWA with good old fashioned resin joints. I would make a 3 way resin joint below ground, no enclosure...
That's a glass half full thought 🤔
2 3
