Pendant light only works with energy saving bulb
L
lukemartyn78
Hi,
I've just had a new ceiling pendant fitted with a dimmer switch. For some reason the light doesn't seem to work with a standard bulb (bayonet fitting) but when I put in a energy saving bulb it does light up (although flickering as its on a dimmer) so the pendant is obviously wired OK?
Any ideas as to what the problem may be? (The standard bulbs I've tried are from other working lights so are not the problem).
Second Malcolm's comments, also looks like the earth sleeving is a little damaged and there's no conductor identifier sleeving on the switch wire. I would fix those 4 issues before going any further.
