Long shot but you don't have another identical fitting that's still connected by any chance?
Discuss Pendant light with no colour coded wires in the The Welcome Forum area at ElectriciansForums.net
@Rpa07 Hows this
If I need to I will but the light is in the dining room where I'm having Christmas dinner and I'm away from home from tomorrow until Christmas day so I can't get someone in in between.
Yeah, but they were binned. The light was already up and had to be taken down, the plasterer who took it down didn't leave me anything to work with unfortunately
If polarity of the line and neutral isn't an issue as long as the earth is good, am I good to go as long as I make sure the earth is connwcted correctly....which I'm confident in doingA continuity tester would be able to identify the wiring for you.
It may be possible with much effort to physically trace the wires if you were to undo the nut at the base of the light fitting and separate the two halves but this could lead to there being lots of bits of light fitting all over the place and tracing wires through the flex is very hard.
The wires do show in the pictures that there is a grey stripe on at least one of the wires, though it may be on all of them, and so this might help tracing.
The wires should be one line, one neutral and one earth, the polarity of line and neutral will not matter on a G9 lamp but the earth identification is crucial to avoid an electric shock.
Even if you have a bulb and a battery with bits of wire to make a circuit you can use this on the wires (when disconnected from the mains supply) of the light fitting to trace them. The G9 lamp holder will have two contacts, one to either edge of the slot, make sure you are not shorting across the contacts and getting false readings.
One wire should go to one side of the lampholder, one wire to the other side of the lamp holder and the earth wire to the metal casing of the light fitting (similarly to the green wire you have already).
I think you have not quite followed that the three cores that are clear are probably (not definitely) line, neutral and earth.If polarity of the line and neutral isn't an issue as long as the earth is good, am I good to go as long as I make sure the earth is connwcted correctly....which I'm confident in doing
Not worried about neutral to live then?drawings are great
Thanks for the great options, I'll not be able to get to this until Christmas day now, however the 2 wires on the left were cable tied together so I'd assumed they were the same ....looking more like a job for a pro!I think you have not quite followed that the three cores that are clear are probably (not definitely) line, neutral and earth.
The green wire is earth as well; there would be two wires going to the earth terminal on the ceiling.
For the three clear wires there are six options as pictured below, the ones connected via blue arrows will be, in this case, equivalent.
However if your identification is wrong then the light fitting could be deadly as the metal body could become live.
It is important to know which wire is which to avoid connecting a live cable to the body of the fitting.
Noo!... however the 2 wires on the left were cable tied together so I'd assumed they were the same ....
Not worried then.
Nope its only you can see it.I've never quoted my own message
Reply to Pendant light with no colour coded wires in the The Welcome Forum area at ElectriciansForums.net
