pendent problems BIG TIME | on ElectriciansForums
Discuss pendent problems BIG TIME in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
R
Ryan saint
Just first fixed a new lighting circuit it a domestic dwelling I've wired it in 6mm t&e to avoid any vd over the 20m circuit. Now here's the tricky bit how the hell do I second fix this into a pendent, I was thinking of cutting some strands of the cores, will this comply with bs7672?
Over 20 meters, ....Wow!! I bet every standard domestic lighting circuit in the UK is over 20m, and they are wired in 1mm or 1.5mm!! lol!! This IS a joke isn't it??
If you're trying to be funny, get your facts right!
Or has a blood clot got into your brain, hahaha!!!
BS7673 says in this situation forget the pendant and wire it into a socket and leave it dangling...then wire some singles to a plug and then via a voltage optimizer wire it to 500w floodlight...thus providing heating and lighting...simple science...
Do you not own a copy of BS7673 the dummies guide to lectrics?...
when you think you've heard it all, along comes another wind-up (or a muppet).
- - - Updated - - -
so what was the volt drop calculation for 1.5mm?
Reply to pendent problems BIG TIME in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
