pendent problems BIG TIME | Page 2 | on ElectriciansForums
Discuss pendent problems BIG TIME in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Just first fixed a new lighting circuit it a domestic dwelling I've wired it in 6mm t&e to avoid any vd over the 20m circuit. Now here's the tricky bit how the hell do I second fix this into a pendent, I was thinking of cutting some strands of the cores, will this comply with bs7672?
Your problem is you real should have used 10mm t&e ! to avoide VD ........... ask the boys at ScrewFix if it comples with bs 7672.5
You should of wired it in bell wire, coiled it up a couple of times then not only do you have a great light source but a great room heater too!!
Reply to pendent problems BIG TIME in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
