Peoples thoughts Rcd protection | Page 4 | on ElectriciansForums
Discuss Peoples thoughts Rcd protection in the UK Electrical Forum area at ElectriciansForums.net
Gazthesparky
Glasgow
I can not make up my mind what to do for the best.
I've now encountered this a few times so just want peoples thoughts on this situation
I have a customer who wants single socket fronts swapping for double conversion sockets they don't want the mess to the decoration.
I went out to quote for the work and check the wiring all PVC so good there but there is no RCD protection on any of the 3 socket circuits. The board is a GET 60898 MCB board confuses me why people installed boards with no rcd protection at least on the socket circuits.
So if i look at installing RCBOs in-place of the breakers its very expensive plus GET doesn't exist anymore as i believe schneider brought GET out so at best im hoping one of those RCBOs will fit.
But doing this means that the 3 RCBOS that are required cost more than the materials cost for the sockets and customers are not prepared to paythe extra cost.
So my question is as i'm just replacing the socket fronts and not actually altering the wiring do I need to install RCD protection to the circuit? If I was altering the circuit I would of course install it with RCD protection. I always carry out testing and provide a test certificate but I know from conversations on the forum before that some of you suggest that simply replacing an accessory front doesn't require testing and certification.
So just want to get peoples thoughts as its adding an extra 72ish quid to my quote. My thoughts are not to do the RCBO addition as i'm not altering the circuit just doing replacement. Then listing it as a note on the test certificate
Cheers for your thoughts/recommendations
Reply to Peoples thoughts Rcd protection in the UK Electrical Forum area at ElectriciansForums.net
I seem to find two types of installation in older houses in which electric showers have been added: those with shower fed from an MCB without RCD...
nicebutdim
N
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
