P
paul 1971
hi i was wondering what to charge per circuit for a periodic inspection in a factory unit
Discuss periodic inspection prices in the Talk Electrician area at ElectriciansForums.net
£35 per circuit, don't work for pennies, if you are competent and have a good working knowledge of BS7671, then charge for it.
Spoke to a landlord by me today as my buddy has just rented a house of him and he pays £35 per property for PIR's.
To which I answered "Good luck with that"
Mitie Epsilon ect ect are charging around£10>£15 a circuit from what I gather if its a factory , large contract guys doing 30 circuits for 8hr shift ( this may sound excessive but bearing in mind a lot of circuits are right next to DB and even just a Zs counts as tested circuit high lights given IR (L.E N>E only) counts as test If a circuit isnt located with in 20mins Leave it off and advise client to notify you if any equipment doesnt apear to be working at end of shift turn it back on Id probably go at£25 for a one off factory with a survey n£35 per circuit, don't work for pennies, if you are competent and have a good working knowledge of BS7671, then charge for it.
Hi Guys
There are companies on the net advertising £8 a circuit for a periodic inspection report
Reply to periodic inspection prices in the Talk Electrician area at ElectriciansForums.net
