N
nickblake
Dont you just know it when you get the call ive no earth on my sockets i would like my electrics tested , walk through the door and greeted by an elderly lady and the first thing you see is a round bakalite switches dating back to the 40's old wylex CDU with ceramic fuse holders ,VIR meter tails that crack nicly when moved, VIR cables every where kitchen sockets tapped off a VIR cooker supply wired in 2.5mm ,shower 9kw installed by a plumber 4 mm cable so sign of where its connected , old round pin sockets ,ring main installed in lounge sockets metal clad surace all wired into the lighting circuit , fuse wire for that circuit 15 amp , no cpc's in the lights metal clad fittings , house nicely decorated and then they ask is it dangerouse and illegal , argghhh where do they get the illegal bit from !!!!!!!! poor old dear got to have the house rewired top to bottom walls chased ,and her son uses the garage as a work shop supply wired in 6mm YY flex under the ground beautiful garden , and the wiring well DN had to be issued TWE cable stripped off and then wired into a light catching the garage door when opened , terminal block joining cables to gether every where no bond or RCD's broken back boxes ,cracked sockets.
hope to put a few pics up what do you do re wire asap
