Periodic Question | on ElectriciansForums
Discuss Periodic Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, doing a periodic on a bungalow, the rear garage has a big blow up pool in it, not a fixed pool but is used in there. Will the sockets and lights fail if not ip rated?? Thanks.
I agree with Hightower, this isn't a 'special location' by design. Kind of like having the tin bath in front of the fire (like the good old days!)
Code 5 - make sure you comment on it on your report, so that the situation is highlighted and documented - remember its your --- that will get kicked!
agree with murdoch except for the --- bit. we ain't yanks so the correct terminology ( as we should all use at all times) is arse.
Im going to agree and dis agree here , you are carrying out an inspection , agree with a difficult one to code but how ever the pool is tempruary , but when the pool was installed in there the garage was then changed to change of use from a garage to a room containing a pool which when this is done also changes garage to special locations so has to be inspected as that i do agree with high tower that its temruary but its a pool full of water and the potential is real , so if some thing happend and some one was killed what would you tell the judge , just my thoughts
Reply to Periodic Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hopefully there's an RCD feeding the garage Cu.
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
