H
Hobsoni
Hello, recently asked to carry out PIR on property. There are test stickers on the cdu to so say it has been passed befoe however client does not have certification. Everything seems in order, but the water pipe thoughout the building is plastic pipe, so there is no bond. (No gas in use either)
On cert- the section regarding characteristics of supply has 'method of protection against indiect contact' normally there is a bond so i would put EEBAD. However in this instance im a bit stumped.........any suggestions??
Many thanks
Many thanks
