G
graham123
Doing a periodic on some rewirable boards, obvoiusly no rcd protection, Would you reccomend to the client the boards be changed?
Discuss Periodic Rewirable Board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Dont know If people have looked closely at the Wylex type of rewirble fuse boards? Without the screw on cover over the fuses there is exposed live parts on show under and on top of the fuse carrier... about 2- 3mm
If the fuse cover is missing (not the carrier but the 4/6 way cover) and the fuses can be seen, this goes against reg 416.2.2
If the cover is there and can be undone without a tool then again I think this goes against the same reg.. what you guys think?
look at the top of this board, hope the link works!!
Redirect Notice
Reply to Periodic Rewirable Board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
