Permament Live to Hive multizone | on ElectriciansForums
Guest viewing is limited
Discuss Permament Live to Hive multizone in the Central Heating Systems area at ElectriciansForums.net
Aberdeen
Hi, im having issues with my hive multizone and getting power to my upstairs receiver. I have 2 zones, upstairs and downstairs. I can only get power to my upstairs receiver when my downstairs heating is on. I have installed a loop wire between live and common in my receiver upstairs but still no power unless downstairs heating is on. Any advice on how to get permanent live to my upstairs receiver is much appreciated. Ta.
This is where the main receiver downstairs goes and where my original programmer was
[ElectriciansForums.net] Permament Live to Hive multizone
This is where my upstairs stat was and where the receiver for my 2nd zone goes. It is here where i can only get power too when the boiler is on.
[ElectriciansForums.net] Permament Live to Hive multizone [ElectriciansForums.net] Permament Live to Hive multizone
This is where the thermostat downstairs was.
Is that a 'blue' insulated conductor used as a 'live' link?
Sounds like the 'live' feed is switched on the CH ON terminal instead of Perm Live?
Reply to Permament Live to Hive multizone in the Central Heating Systems area at ElectriciansForums.net
R
Hive thermostat multizone help Can anyone help me. I have just moved house and we have a boiler with a separate hot water tank and then 2...
Rick1980
R
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
