Permanent Diesel Generators Installed Inside a Building | Page 2 | on ElectriciansForums
Discuss Permanent Diesel Generators Installed Inside a Building in the Talk Electrician area at ElectriciansForums.net
The length of the exhaust needs to be kept to a minimum to avoid the need for mechanical extract.
Ok you really need to offer up more information if you want help with this.
The lads will happily answer your questions but please give them a bit more to go on.
I think there are a page full of replies asking you for clarification so maybe answer all those first.
I have to make a design for generator room with all installations ( ventilation, air supply, exhaust) and obviously all wiring
Don't forget EM lighting either, non slip flooring, emergency exits large entry doors for getting large equipment in and out.
If the generator is appreciable size then you need some detailed guidance from someone experienced, there are a lot of considerations that are beyond the scope of friendly forum advice. This site gives an impression of what's involved.
Thank you everyone for all advices. I haven't got problem with the wirning, structure, exhaust. But what I am struggle it is only capacity of the room and ventilation ( because what is mean good ventilation ? How many air ? )
Reply to Permanent Diesel Generators Installed Inside a Building in the Talk Electrician area at ElectriciansForums.net
Even if it’s says that the neutral is bonded to the generator, you still are required to install a ground wire from the generator to the transfer...
Hi all, Just wanted a bit of advice in regards to a small installation of emergency lighting. I have a fairly long warehouse that needs some...
