Whhhhyyyyy????? Why do people snip cpc's off when its so simple and takes a matter of seconds to connect it!! All i had to do was replace a pendant with a 6ft fluorescent in the loft, tested for zs and no earth even though it was connected at the light! It was cut off at the switch so i joined it there, still no earth! Traced cable towards landing light but no cpc's and no permenant lives in fitting! They were stuffed up above the light in choc blocks and wouldn't pull through so i had to take boards up in the loft to remove choc blocks and connect them properly in fitting! Hour and a pigging half to do a ten minute job just because some cretin couldn't be bothered to spend ten seconds connecting a cpc!
