Pet Hates | on ElectriciansForums
Discuss Pet Hates in the UK Electrical Forum area at ElectriciansForums.net
T
tbs1983
1.Twisted Earths,
2. dodgy threads on metal back boxes,
3. that horrible cellophane and foil inside some brands of FP200,
4. cheap soft brass terminal screws on switches/sockets etc.
5. snapping small terminal screwdrivers cos I'm too lazy to get the bigger one out of my toolbox!
1) drill with dodgy safety clutch= oeoeoeoeoe clatter ...(hits wall)slide...splat...hobble...hobble daaafuuuu kkk ...swing swing swing ...swing...gone.....(tescos carpark 300 yds away)....smash..
2) cheap holesaws that fall apart in 10 seconds...
3)drilling conduit boxes...
4)tools that magically get swapped for broken cheap old crap by someone else at tea time...
5)being on site in winter when someone decides to turn off the generator on their way out, cutting the lights....
6)having to buy a tool needed on the day and getting stung rip off prices for cheap cr@p because nowhere nearby sells decent ones....
7)scaffold getting off hired when I needed to use it....
1. Certain makes of armoured glands where you can't get the back nut on.
2. Cheap metal conduit boxes where it's not a true 90 degree angle.
3. Bushes that snap.
4. Connections in accessories that wont tighten up as soon as you put the end of your cable in.
5. People borrowing your kit then not bringing it back.
6. Multiple earths in one sleeving
1)poor workmanship (which i normally have to fix)
2)laziness (which i normally end up working late for)
3)untidyness (which i normally fall over)
4)and whoever it is that keeps removing schedules from most of the dbs i have to work in
1)lifting carpets
2)lifting floor boards
3)refitting above
4)can i have a discount
5)its only a small job
6)cow boys
7) pozi drivers that snap
8)battery dead on drill
9)torch no battery while under the floor ...................
to de mag a screwdriver strike it on a hard metal surface
one of my pet hates is cell phones
but the worst is some theif swapping the battery in your drill for their duff one
police men on bikes
so what if i am eating a sarnie whilst driving i could talk on the phone eat a sandwich and hold coffee cup between my leg and change gear and i still would not be as dangerous as that mini cab driver
bus drivers - yes i know i stopped on a double yellow - you do not have to pull up alongside me and pretend you cant get through - you could get a bus through there mate!
All of the above...
What is it with schedule one...full distribution panels with no schedule...why has someone removed them and not put them back????...its near on impossible to trace anything in large plants...I can just imagine them hidden under loads of junk in someone's van...really annoys me...
All of the above...
I just imagine someone doing it out of spite or using them to do material lists on. its so annoying especially on new jobs where you know it may not have been there from the start which brings me back to points 1 & 2
The wonderful customer supplied lights from various retail outlets that have no space for more than one cable and require you to support them with one hand while trying to connect the cable with the other two. Then you have to try and support the fitting while trying to get those pesky little screws into the mounting bracket. I always end up dropping them and have to do a pull test on my connections while I grovel around on the floor trying to find them. AAAaagggghhhhhhh
Reply to Pet Hates in the UK Electrical Forum area at ElectriciansForums.net
