PEX Crimp ring test plumbing advice | on ElectriciansForums
Discuss PEX Crimp ring test plumbing advice in the Plumbers Forums area at ElectriciansForums.net
PEX Crimp ring test I'm installing PEX b for the first time, and I was wondering if the Go no go tool needs to fit correctly on all sides of the ring after crimping. I did one fitting and it fits correctly on one side but doesn't fit if I try the other direction. Any insight?
PEX Crimp ring test to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to PEX Crimp ring test plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Emmeti manifold to new radiators. Hi I'm I've just joined and hope to gain some well needed knowledge! I'm replacing the old 1 pipe heating system...
Dobbslc
L
What manufacturer makes the best quality fittings for multilayer pipes? What manufacturer makes the best quality fittings for multilayer pipes...
LordWest
L
