PFC & Earth Loop Imp Tests. | on ElectriciansForums
Discuss PFC & Earth Loop Imp Tests. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
OldskoolUpNorth
Alreet all,
Went for an interview for a FM company recently and got asked a couple of, what I thought were, ambiguous questions.
Thought i'd find out what everyone else thinks.
1) What would you expect to find during PFC test?
2)What would you expect to find during Earth Loop Imp test.
Answers on a postcard.........
Neil.
Possibly the following:
1) A result in kA that determines the fault current likely to flow in the event of a fault. The lower the external impedance of a supply, the greater the fault current would likely to be. I'd also explain to make a note to check whether the MCB's/RCBO's and switchgear within an installation are likely to be rated to the prospective fault current.
2) A result in ohms, which complies with the relevant earth system value, TT, TNC-S, TNS etc. The Zs result that you obtained may also need investigating if it is greater than your Ze test and your R1+R2 test results combined.
Any comments welcome!!
Thanks Test-Meter,
Answers,
1) No more than 16kA except in parts of London
2) Max 1 Ohm
Now call me crazy but that doesn't sound to me like the question they were asking.
I thought they were after an explaination of the relevance and not a max value.
I got No1 right but went into the details of Ze with No2.
Why can't they say what they're looking for rather than being vague... Jeez!
2) Max 1 Ohm
if they've ever worked on a TT system, they're dreaming, unless the rod/s were installed by eng54. LOL.
Thanks Test-Meter,
Answers,
2) Max 1 Ohm
Well, 1 Ohm is the maximum for which system? Its 0.8 for TNS and 200+ For TT, this was a pretty poor question.
Can you see my confusion?
I was on about a range of values dependant upon blah blah blah...
and the answer I got
'Your over thinking it'
No specific system mentioned, no details whatsoever, just the question.
Thats a rubbish question probably taken straight from a city and guilds paper, they seem to be the main crap question purveyors!
typical suits. read a few bits and think they know it all.
my answers would have been.1. expect my 1552 to show a PFC reading. 2. expect it to show a Ze value.
I'm very familiar with C&G's type questioning, and even they wouldn't try some imaginary nonsense like that.
I'd have offered him some educating.
I've seen things like this before myself. I once went for an interview at a company in Leather head and the interviewee wrote down three formulas, each with a symbol missing and he asked me to find them. The answer to all three was 'I' and I think maybe I intimidated him from asking any more..
I got the job, but I wasn't interested any more.
Reply to PFC & Earth Loop Imp Tests. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good thinking - the other side of that is my garage and also where the gas comes in so probably quite a tidy solution if it comes to it!
If they got a shock then something cannot have been isolated.
