C
CERTA
can anyone tell me the stated difference between prospective short circuit current and a prospective earth fault current test
cheers certa
cheers certa
Discuss pfc pscc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
pssc is the max current that can flow between Line & Neutral.
pefc max current flow between line earth.
If TNC-S using ohms law they will be the same.
Prospective Fault Current is not the same as Prospective Earth Fault Current. PFC is the greatest of the PEFC and the PSCC.
Reply to pfc pscc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
