PFC Readings | on ElectriciansForums
Discuss PFC Readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chloebear
Hi All,
Just a bit concerned :confused: about some low PFC readings taken recently, all on TT supplies. 1st reading was 1.1Ka on Live/Nutral and 11A on Live/Earth with a Ze of 65 ohm for the earth spike and 2nd was 1K on Live/Nutral and 9A on Live/Earth with a Ze of 28.5 ohm.
Just a bit concerned about the low PFC reading Live/Earth or are these Ok????????
These readings should be ok as it is the highest kA reading that is noted on cert. On a TT this is generally live / neutral reading.
Reply to PFC Readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
