Phases in dado trunking. | on ElectriciansForums
Discuss Phases in dado trunking. in the Commercial Electrical Advice area at ElectriciansForums.net
Uk
Hi all and thanks in advance for any replies.
I was wondering if whether when having more than one phase inside a dado trunking are you required to mark up the trunking with a 400v marker/label like you would at a multi gang light switch??
Cheers
Cheers
No requirement.
According to bs 7671 a warning label is only required when the line to earth voltage exceeds 230 volts ac. You would only have 400volts between phases.
I still however label a 3phase db with a 400v sticker/warning notice just the way I was taught and I think it's good practice
Cheers
No there is no requirement.
Cheers
I don't know if it's a requirement (ignore that cheers lee:D) but I certainly would, not a big sticker but maybe the smaller etched ones placed on the lid, just in case someone who isn't competent decides to have go at chucking a couple of extra sockets in.
Reply to Phases in dado trunking. in the Commercial Electrical Advice area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
