phone charger for use in a bathroom. Is there such a thing? | Page 2 | on ElectriciansForums
Discuss phone charger for use in a bathroom. Is there such a thing? in the Electrical Tools and Products area at ElectriciansForums.net
when in Germany last year when in a upmarket air bnb there was a wireless charging pad on both the coffee table and another in the kitchen work top.
Took a look and were both selv you can buy little attachments like a power bank that plugs into a phone or similar device so it can charge wirelessly.
In theory you could have one on the tiles on a bathroom and put a little attachemt onthe fitbit and it will charge. Dont see an issue if its selv and well made.
Thanks for everyone’s suggestions.
I’m going with a 2 port euro module similar to the mk one mentioned earlier.
Just need a nice long lightning cable so I can charge my phone and play games on it while sitting on the throne.
Do look back at the thread. The MK module is one of the few SELV USB products.
Cheaper ones may not have this essential safety feature and are not permitted in bathrooms.
Just thinking. I use a fitbit, and I got into the habit of charging it every few days when I had a shower. (charging it every few days, not having a shower every few days!:rolleyes:)
Is there something i can use inside the bathroom to give me a standard 5v USB socket?
Of course you can get a single socket with a usb in it, but cant use that in the bathroom.
Could I take a supply from the shaver socket, but would it have to come from the output side of the transformer?
Could I use a regular plug in usb charger with European pins and plug it into the shaver socket?
Any thoughts?
Or bin the fitbit get trainers run till your knackered, walk back , you know like we did in the old days
Be careful using shaver sockets. They have very poor regulation and can go up to around 280v on very low load such as a phone charger. If your charger is rated 100 to 240v use the 110v socket which on low load is around 130v.
Just for the sake of the thread. The MK module mentioned has ‘don’t install in a bathroom’ in the MI despite the SELV rating.
Found while my electrician was working through my new refurb spec!
interesting, probably due to high moisture levels corroding the internals.
more a warrenty issue than a safety issue I expect.
but if the MI says no then,
it is unsuitable for that use.
Reply to phone charger for use in a bathroom. Is there such a thing? in the Electrical Tools and Products area at ElectriciansForums.net
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
