Photocell with manual override | on ElectriciansForums
Discuss Photocell with manual override in the Australia area at ElectriciansForums.net
E
elementps
Hello,
Have been asked to fit some garden LED light fittings, supply will be coming from fused spur, total load less than 1A. The customer wants a photocell switch fitted but also ability to override and manually switch on/off when desired.
Anyone dealt with this before, would you have any wiring diagrams, descriptions?
Many Thanks
i would wire the photocell normally then wire a switch across the Lin and Lout of the photocell. or use 3core/E from spur, 3rd core to supply L to Lout on photocell via switch.
Reply to Photocell with manual override in the Australia area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
