piceing | on ElectriciansForums
  • Thread starter andrewcann
  • Start date
  • Replies 1
  • Views 1K
Discuss piceing in the Business Related area at ElectriciansForums.net
A
andrewcann
hi all have got a small job just come up and this will be the first one since going alone so got to price it right it is to change some son outside lights all lights are supplyed as well as a tower was thinking of 10 pounds a light fitting dont need to get anythink only changing lights about 8 in total does this price seem right to you alot any help would be good
Have you already tested the circuit? Are you likely to come across problems? How long will it take you? What body are you with? Remember you've got to cover the cost of your testing and certification too. Personally I'd want best part of £80 just for that, without actually changing the things. If the council are coming out to check it over and you're just swapping the fittings then going home then I guess a tenner each is fair.
Reply to piceing in the Business Related area at ElectriciansForums.net
Depending on the location of the 2 CU's and the quality of materials I'd say £10K-12K. If they're potential tyre kickers don't waste loads of time...
    • Informative
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
