rsgaz
what way a fuse goes in a car
With ordinary fuses in a 'normal' fuseholder it doesn't matter at all which way round they go. It's only when you introduce fancy fuse taps and whatnot that you need to check which way they go.
If i do have an empty slot that has power +12v permanent can i assume it will take 15A?
each wire from the back of the hazard switch
