PIR coding | Page 4 | on ElectriciansForums
Discuss PIR coding in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Nottingham
Hi guys,
Doing a periodic on a cabin which is to be used for buisness use.
Its a new install and the one thing i have seen which im not sure weather it warrants a code or
not is they have a chandelair type fitting where the bracket is screwed to the beam,
Meaning due to the size of the fitting its possible for someone to put there hand above the
fitting and go into the connection behind it.
The height from floor to the fitting is 2.25m
would you guys snag this.
thanks
Doesn't really matter whether you believe they belong in the same category.
The simple fact is that they are in the same category.
Hence uninsulated High Voltage cables on pylons, overhead lines for rail and tram lines, etc.
We are talking about a simple installation here, a light fitting at that.
It's hardly in the same league as the national grid.
for me it's exposed live parts C1.
Probably easy enough to sort fairly quickly with much less effort than has gone in to this thread. :)
Reply to PIR coding in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
