Pir light + switched light | on ElectriciansForums
Discuss Pir light + switched light in the Lighting Forum area at ElectriciansForums.net
Anthony16090
Uk
Hi
Looking for some help.
Is it possible to wire a pir light that only has line-neutral-cpc
With a normal outside light normal connections via a light switch.
So both lights come on when the switch is operated but only the pir light works when the switch is off
nah. this is a carp !
[ElectriciansForums.net] Pir light + switched light
he meant:
Reply to Pir light + switched light in the Lighting Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
That should be what your looking for...
