Yes so keep the brown blue from board at pir and take black from board via key switch to em light? Then out of pir s/l, neutral and earth to each light fitting? Is this correct?
I ask again, why blue? But hey, as you are in trouble:-All wired in singles in conduit. I’ve take the 4 singles straight from board to pir. Don’t think cables are long enough to go to first fitting instead now either..
SWITCH....has 6 letters, not 4.****** off then
I see your use of the Engish language is on a par with your electrical knowledge.**** off then
Reply to the thread, titled "Pir lighting circuit.. help!!" which is posted in Commercial Electrical Advice on Electricians Forums.
