PIR "no RCD on shower circuit" | on ElectriciansForums
Discuss PIR "no RCD on shower circuit" in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Jazza
A friend of mine has had a company do a PIR on there property, must be renting it out or something.
They were told they needed RCD protection on there shower circuit as an urgent requirement.
Is it possible to fit an RCD after the 45a mcb for the shower circuit. The cable is surface mounted with loads of slack and as they dont want to change there old school Consumer Unit.
thanks for the reply. Unfortunately it is only surface mounted in the cupboard where the cu is. I put that info in because there is a bit of slack on the cable and an rcd could fit in nice between board and shower.
lol, it did seem a little like that, company was gas elec. supplementary bonding is present but cable is not surface mounted the whole way just can see it as the only cable going up the wall. meaning the rest are buried and someone must of added the shower in at a later date.
the board is an old style wylex, not sure what fittings you call them, but someone has put some ge mcbs like you see on the newer boards.
can you get an rcbo for that
as regs changed in 2008!!! if it was existing and it was installed to 16edition then its fine (providing bonding is connected)!
to many people jump on the RCD "save you life cover all scenario"
if a recent addition then 17th would stipulate RCD etc....!!
they have installed push in MCBS!! you CANT get push in RCBO!!
back to original question thoough yes you can install a RCD "After" the Fuse! or why not split the tails and install a Standalone box for shower!!
because if it was compiant at time of installation, the only needs a code 4 on the PIR
ahh I see, I dont think its a recent edition as it is wired in the original red and black. If they still want rcd protection on that circuit, is it ok to put it on the demand side of the circuit, due to the cable being visible?
Reply to PIR "no RCD on shower circuit" in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
