pir on a office building | on ElectriciansForums
Discuss pir on a office building in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
Tapouchoke
hi guys
I am currently carrying a pir on a office building 5 yrs old
Tested all the circuits for r1-r2 zs rcd times ect but removed the insulation resistance tests as the building is full of it equipment (IT building}
Listed this as our limitations on the report can anyone advise on how the limitations should be worded :confused:
Inspected the Characteristics of primary supply overcurrent device. A Random Sample of Accessories Removed for Visual Inspection of Connections, Ie 20% of Lighting and Power Insulation Resistance Tests Have Been Omitted Due To Sensitivity of the Site, HVAC control cables. Testing of unverified circuits. Has Been Omitted From This Report
thanks in advance
Sounds ok, you need to be very clear and concise about what you have and havn't tested though, particularly where sensitive equipment is present, last thing you want is the blame for 100 P.C's going belly up. Also, dont forget that any limitations must be agreed with the person ordering the work too.
Cheers lenny
Just want to cover my butt & do the job right
[ElectriciansForums.net] pir on a office building
Reply to pir on a office building in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
If they got a shock then something cannot have been isolated.
