I am mounting a PIR to junction box.Will it work ok in this orientation with adjustment buttons on bottom?Does it need rotated 180 degrees so buttons are on top?
Discuss Pir orientation help in the DIY Electrical Advice area at ElectriciansForums.net
No instructions with item.Bought off eBay.Some pics show PIR attached directly to light with buttons showing on top.I can always rotate the pie but thought buttons would be better underneath.Thanks.They are normally on the bottom what orientation do the instructions show.
If the buttons are on top, then likely it will fill with water, perhaps?
Reply to Pir orientation help in the DIY Electrical Advice area at ElectriciansForums.net
