PIR question | on ElectriciansForums
Discuss PIR question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
U
Uptonelectrics
I have come across a FORE alarm system for communial areas of a block of flats which has relays which activate the alarm when a vent at the top of the stair well is operated. any ideas how to test it for compliance?
Why would a pir activate a vent system...? are you not working on a communial vent extraction, which is basically a fire alarm which activates vents. If so be careful on you next move, after the Tower Hamlets fire, I think there is a good possiblility of changes here...and rightly so IMO
Are you sure it is a PIR and not an Optical Smoke or perhaps a heat detector? Most likely I would put money on an old style Optical smoke detector, I remember some that the uninitiated could confuse with PIR's used for security systems.
Reply to PIR question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Shhh, don't tell the Chinese they want a bit of the action.
