Hi,
I'm doing my first report, and the installation what i got has lot of DIY marks on it.
What do you think:
-If cpc used as a line conductor in a lighting circuit ( 2way switch), code 2 or code 1 recommendation are you suggesting ?
-On another lighting circuit the IR test between live and earth conductors is 90 ohm. (not megaohm). Code 1 and should be isolated?
-Is it allowed to use un-insulated cable with blue and brown sleeving inside the consumer unit (25mm between main switch, RCD and neutral bars)?
Kind regards,
Tom
What do you think:
Kind regards,
Tom
