J
joeyscurlock
I've installed 4 lights, one with a built in PIR operated at the bottom of the garden which allows slave lights up to 1KW, at the top a separate PIR allowing 2kw also controlling the 4 lights. I've used a 4 core 1.5 SWA, using switched live to control all lights and i've let the common flow through down to the bottom PIR so it has a permeant supply as well as switched supply.
I finished the job and it was getting dark, turned the switch on, struggled to do the walk tests as it was to dark seemed to be doing all sorts at the time, staying on, constant flashing (one pir is meant to flash 3 times on start up to say pir mode is active). I told the customer to turn the switch on in the morning, stay out of the way, and see if it was all working. He said the lights went off after turing switch on, then when it was getting dark all the lights activated. I disconnected each pir individually and one is working perfectly and I have established the one which is working as a photocell or so i think. Its not activating when i walk past even when settings are set to daylight but once again it was getting dark by the time this was happening, after messing around with it, i turned it back on but it was dark at this time so it stayed on. I plan on going tomorrow in the day removing the switched live from the working pir and try to get this faulty pir to work.
The working PIR has a photocell function available if you do a sequence on the light switch, faulty PIR does not have this facility or so it doesn't say.
Anyone have any suggestions why this is happening or anyone experienced this before? Very frustrating stuff
