PIR Test high Zs on 32 Amp RCBO | on ElectriciansForums
Discuss PIR Test high Zs on 32 Amp RCBO in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Guest 004
Hi people
I had an high Zs of 0.85 on a 32 Amp type C ring circuit, which was on an RCBO. My first thought was to give it a code 2 'requires improvement', and then change it to a type 'B' so it would conform. Then I thought it is on an 30mA RCBO, where the max Zs in theory can be 1667 ohms. Just asking what you guys would do and why.
Is that not something different as the neutral is not part of the ZS loop.
CNE? or PEN?
On a line to neutral fault it would be the PSCC which would blow the MCB
Indeed, though if we have three conductors all the same csa Neutral and Earth connected at the link, if we have a high Zs then we could also assume a high L -N loop reading.
Ive seen A very similar thread somewhere else:)
Reply to PIR Test high Zs on 32 Amp RCBO in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
Just re-read the OP's post and it is an existing 5C SWA so presumably a 3P supply. For 40A and 150m you are seeing 6.6V drop or 1.65% of 400V 3P...
