G
graham123
am currently doing a pir on some flats, and need some help on a fault code. In the basment their is 4 bs88 isolators off the supply, which feed the 4 flats, the submain to each flat is a 10mm TE with no seperate earth, which means earth is undersized, correct? 1,2 or 4? falutcode as its 4mm. Also the bs88's are 100a which exceeds the rating of the cable, is this a 1,2? thanks
incorrct sized earthing is usually a 2, same with the overrated fuse for the cable UNLESS there are signs of overheating etc
Read Regulation 543.1.1 before you put on code down for that CPC.
The incorrect size of the protection device can be a 2 yes.
pir testing flat, fault code
graham123,
Octopus,
