Dear all,
Please see attached a picture of a wall light from a customers house. The customer has 5 of these in total, they are now getting old and failing (poss due to running led lamps in non led fittings) Each light has a built in pir. They are all wired together from 1 switch inside the property.
They therefore are left on and work independently when sensing movement.
There is also a stand alone PIR on the drive, this sends another feed to the lights (seems bypassing the integral pir & connecting the the lamp) and energises.
The driveway PIR is also powered by the same switch (unable to see where this is joined)
The lights are cabled with 4 core PVC, SW, L, N & E. The L is used for independent use, the SL from the driveway PIR.
I discovered this set up when I arrived to fit the replacement lights supplied by the customer. the challenge is, the new lights don't have a SW option, only L,N & E. I cant get in to the PIR or lamp terminals to add a direct SW feed to the L.
So...... after all that, does anyone know where I can get wall lights in this style with built in PIRs and a SW & L fitting option? None of my suppliers have yet come up with anything.
I should also explain that the property is a grade 2 listed thatched cottage which I am unable to alter the wiring on (the switch is wired normally- one way with just C & L1)
I hope that makes sense!
