PIR with long(ish) range? | Page 2 | on ElectriciansForums
Discuss PIR with long(ish) range? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all..
The customer wants his garden light to switch on the moment he walks into the garden, the sensor is around 12 meters away and it doesn't switch the light until he is half way up the garden. There is nowhere nearer I can locate the PIR.
I realise screwfix/toolstation have PIR's which state 12m but I know that they only work up to around 7-8m.
Does anyone know for sure which PIR's would be good for longer distances? I've found these External Security Lighting Products for Home
they look ok (very narrow spread though - 10degrees) but was hoping for some first hand experience from you chaps?
Thanks.
Good to close out a thread with a proper ending!
I bought the steinel IS140 and was very happy with it. Loads of room for the cable(s). Can have it flush against the wall or slightly off if needed, if cables need to get behind. The main point being it picked up my movement from 13m's away, so I was happy and the customer was happy! :D
Reply to PIR with long(ish) range? in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Recommended Sponsor News
Hi everyone,
