Hi all I would welcome opninions on the planned changes below, this is my own property,
Last year we built an extension as a self contained self catering holiday let, cooker & hood, shower, kitchen ring, toilet and kitchen lighting,
I have a long tails run and the chaps from hydro fitted an isolator (1) between meter out and CU, I intend fitting a fused isolator (2) upstream from this isolator (1) now there is mention of the 3 metres limit for tails I take it thats where I need the isolator (2) I also need to supply the CU in the extension, now I intend to take that from henly's just before my main house CU in 16mm and via a 60A service fuse or maybe I will omit the henly,s and use the service fuse as there will be enough terminations
thoughts anyone
Pict
thoughts anyone
Pict
