plastering a wall chase !!! | on ElectriciansForums
Discuss plastering a wall chase !!! in the Australia area at ElectriciansForums.net
sunny essex
Hi all
what is the best way to fill in the cable wall chase , i have been using multi finish but i am not pleased with the results what do you fellow chaps/ladys do
cheers
Richard
Bit of bonding coat mixed with multi finish
Just putting multi finish in a chase will just end up cracking
By mixing the bonding coat in, it thickens it slightly and makes it easier to apply, having said this i dont bother plastering i trained to be an electrician not a plasterer and truth be told im useless at it, for a good job pay someone!
Bond up the chase with bonding then multi finish once the bonding has gone off a bit. A bit of PVA and water in the chase first helps everything stay moist and generally crack free too.
1 coat will do it ok....you can get it in standard sized bags and if mixed properly will go on good and stay in (i try not to mix it too wet as it can slump if not careful).....drying times about the same as thisle..........
Hi glen spark
do you mean one coat plaster and youcan fill the chase in one go with out cracking or bulging
You can get it from wickes in either small are the large (thistle sized) bags....so it depends on how many chases you have to do....i would say theres always room for some in the van. Now then, You can work and polish this stuff just like a multi or board finish so you just get it mixed and into the wall like normal and then give it a while then just work it with the trowl in the normal way....no slumping,...no cracks,...no fuss...........job done...lol....(a tommy walsh moment)......:26:
Reply to plastering a wall chase !!! in the Australia area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
G
Wall grout for shower Hi, Just wondering what the general consensus is with grout for a shower. I have epoxy grouted the floor but now that I'm...
Garfield28
G
