Plastic conduit bending springs | Page 2 | on ElectriciansForums
Discuss Plastic conduit bending springs in the UK Electrical Forum area at ElectriciansForums.net
T
Toneyz
Bending Springs for plastic conduit someone once said to me that you should tie on end loop and bring through spring it stops it deforming when pulled out.
I don't usually find the end of my spring disappears and I put a piece of metal through the circlet at the end of the spring and twist as I pull out. I never put the spring that far down the conduit. I just use straight couplers to get the length I want.
I'm really surprised this hasn't been mentioned. All you have to do is not send the spring that far down if you are forming a sharp bend, then as you withdraw, place a screwdriver through the loop on the spring and turn it clockwise. This will tighten the spring making it thinner and it will pop out with ease.
I don't think I will be P@:mad:@:mad: about using this method though. What a faf!
Reply to Plastic conduit bending springs in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
