plastic conduit cutters | on ElectriciansForums
Discuss plastic conduit cutters in the UK Electrical Forum area at ElectriciansForums.net
no mess though mate you have to move with the times or are you still using the the bit and brace drill ?
bit n brace.....summat else you can`t use then eh?....
don`t tell me...let me guess...er..no!!
and while were at it n all....whats wrong with a bit n brace eh?.....at least with that you can actually feel what your doin.....important that is sometimes fella....
Junior Hacksaw.... plastic conduit cutters were a solution for a problem that never existed well unless your incapable of cutting straight in the first place :wink_smile:
I find them useful when I've brought a conduit from under the screed to the underside of a kitchen island, I normally leave the conduit too long, and once the island is in place can't get to it with a junior hacksaw. Also the conduit cutters will cut through the conduit, but not the cable inside.
Reply to plastic conduit cutters in the UK Electrical Forum area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
