plastic conduit cutters | Page 4 | on ElectriciansForums
Discuss plastic conduit cutters in the UK Electrical Forum area at ElectriciansForums.net
a spin round the tube before you squeeze sorts this
Only the cheapest of plastic conduit shatters.
Really!!! They must have changed the fundemetal characteristics of plastic in very cold conditions then!! lol!!
Try bending a plastic conduit without warming, or cutting a plastic conduit in such conditions!! From my experience on this forum, most here would be using the cheapest conduit locally available to them, for domestic installations!!!
Who ever though plastic conduit cutters could be such a popular topic..
Junior hacksaw all the way for me, although i can see they would use full in a carpeted area most my work is on building sites.
Can't beat a hacksaw for speed if the crumbs don't matter, but I do have this teeny tiny size pipe cutter (about 32mm ish for a 20mm tube) which is brilliant for tight spaces. Found at a plumbing merchants years ago and not seen since.
Junior Hacksaw.... plastic conduit cutters were a solution for a problem that never existed well unless your incapable of cutting straight in the first place :wink_smile:
But there is no mess with a conduit cutter, have you ever tried to vacuum up The plastic from carpet lol. It also leaves a perfectly smooth finish. So no time wasted cleaning up or de buring
Moving on is difficult for some people, pipe cutters are fast clean and pricise, a hacksaw is slow messy and hanging off a ladder not very precise, but then again some people think fire is the work of demons
Pict
Pict
No-ones saying these cutters aren't any good, just don't try using them in very cold conditions, on just as cold plastic conduit ....especially when hanging off a ladder!! lol!!
In all seriousness in a attempt to over engineer a problem that's no big deal, I constructed a coffin out of 1/2 birch ply, it's 10" across, 10" deep and 2.4m long. One end is open , the other is open with a 45• slope top to bottom.
In the sloped end I put a 2kw fan heater on its lowest setting and the other end I can shove a whole pack of PVC conduit into it.
It's a pain to store and I only ever use it on bigger conduit jobs. But it does mean when we are putting up tube, we have a readily available feed of pre warmed PVC ready to cut and ready to bend.
Now that's very similar to fabrications a contractor used on one of the projects i was on. They fabricated the heating box out of AC ducting. Both the plumbers and the electricians had they're own versions....
EDIT,
That project was the new British Embassy in Poland, long before liberation. -2O/-30C during the winters there!! The main building was actually built twice, the security people came over and did electronic sweeps after a device was uncovered during some alterations. the place was literary riddled with the things, so many, they knocked the lot down..lol!! The local contractor got thrown off the project and replaced with a British contractor, with no local hire allowed, which is where i came in. Never had to work under such draconian security measures before or since.
Reply to plastic conduit cutters in the UK Electrical Forum area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
