View the thread, titled "Plastic CU EICR code?!" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
Hi everyone
I am in two minds on how to code this on an EICR recently completed.
Plastic CU under-stairs and under 150mm to gas meter with a tiny bit of firer retarded board between.
By looking through regs I've come to C3 but I'm extremely nervous about it.. C2?
Any feedback appreciated. Thanks
Georgie.
C3, not to current standards. A plastic unit is no more likely to burst into flames than a ferrous one, especially so if the last one to work on it was skilled and diligent enough to tighten check everything before popping the lid on, even if such concepts are outdated.
Reply to the thread, titled "Plastic CU EICR code?!" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
