Plastic light fitting | on ElectriciansForums
Discuss Plastic light fitting in the UK Electrical Forum area at ElectriciansForums.net
C
ChristopherJoe
Hi to anyone who could help please,
In the below light fitting I have connected a single (red) wire to one side and a single neutral(black) wire on opposite side. There’s a spare black wire and three earth wires which I’ve connected to wago connectors. There are three spare reds which are isolated with tape that are not touched. When I turn the mains on the light comes on but cannot switch off. When I took the previous light fitting off the live, neutral and earth were connected correctly to respective terminals and could switch off fine. Why am I unable to turn off the light does anyone have an idea please
Chris
  • [ElectriciansForums.net] Plastic light fitting
The “spare black wire” is a little concerning.
You really need to employ an electrician to trace the cables and find out which ones are live, switched live and neutral.
We can possibly “best guess” but we are unable to give step by step instructions due to forum rules.
If you post your location, there may be a forum member local that can help out
Did you take a photograph of the old fitting, before disconnecting anything?
Hi,
Thanks for your reply yes I’ve attached below, there’s two black neutrals and a single red. With the new fitting I’ve used the same red and one of the blacks used a wago connector on the other. To be honest I’ve tried both blacks on their own and together in the new fitting and I have the same problem?
Thankd
Chris
Hi,
Thankd
Chris
What you have done here is create a very dangerous situation by disconnecting the outgoing neutral wire, this will lead to it becoming live and a number of light fittings in the property not working but having both connections live.
It would be best to get an electrician to fix this for you and I would advise switching off the lighting circuit until it is fixed.
Reply to Plastic light fitting in the UK Electrical Forum area at ElectriciansForums.net
As said, looked like there was enough cable slack to correct direct and avoid fitting the wagos in ceiling void
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
