plastic pipe and earth. | Page 2 | on ElectriciansForums
Discuss plastic pipe and earth. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm a kitchen fitter,who uses end feed solder fittings(cheaper).
This situation with the earthing requirements is confusing,so I just earth it all,unless its obviously all plastic.
On a similar theme,how does ptfe tape on gas affect the electrical conductivity?
you would probably have tapered threads and the threads would bite thru the ptfe so I doubt it would affect it.
Sometimes if you talk nice to the plumber, he may put in a short piece of copper from the main stop cock for you to attach your clamp to.
I thought that the idea to bond to the water and gas was all part of the means of ADS if the incoming water / gas is plastic what possible good does it serve?
Reply to plastic pipe and earth. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
This is an RSS feed of thread: Best way to connect 10mm plastic pipe to 8mm micro bore Content of the thread: Hi all fitting new radiators and...
