plastic wire gauge - mm | on ElectriciansForums
Discuss plastic wire gauge - mm in the Electrical Tools and Products area at ElectriciansForums.net
gazdkw82
leicester
I seen somewhere not so long ago a plastic credit card size wire gauge. It had all different sized cut outs in it so you could offer up a conductor in order to correctly size it. cant find anything decent that's measured in mm.
Its just to quickly size a conductor if in doubt
make your own from a bit of metalplate' . calculate the diameter using A = Π Γ²
That one I linked to, I'm pretty sure that is giving the diameters, rather than the CSA.
You'd need to work it out differently for stranded if you make your own.
Do you have some digital calipers?
yeh I have some.
Then just make a table to print out of CSA & diameter and use the calipers to check.
[ElectriciansForums.net] plastic wire gauge - mm
I can upload the xlsx file if you want it to make it look prettier or change it about a bit.
Reply to plastic wire gauge - mm in the Electrical Tools and Products area at ElectriciansForums.net
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
