PLC help required for beginner | on ElectriciansForums
Discuss PLC help required for beginner in the Talk Electrician area at ElectriciansForums.net
UK
Hi everyone,
I've just got hold of a FX3U-24MR unit. I've no previous experience with PLC's at all but have a little with Arduino and Rpi, so I'm hoping to teach myself as I go and looking for a good community to help.
I've got a project at work which I'm going to start - it's basically a motor and safety brake which has a braking monitor system to detect whether the brake is on/off, temperature, wear monitoring and a few other requirements.
Now for the silly questions...
1). The PLC came with a RS232 cable... is that what I program is with? I've only got a laptop so can I get a USB interface?
2). What program do I need to install so I can play around with ladder logic and download to the PLC etc? It says it's compatible with GX-developer and GX-work2. Are these free? Finally, does it burn it to the PLC or does it need to run live via the data cable?
Hopefully someone can help me get started and any other tips, no matter how simple they are would be greatly appreciated. Thank you.
Hi
You can download free fx configuration software, hi on the other hand as far as I know isn’t free and unfortunately very expensive..
USB to rs 232 cables are a standard item..
The program is downloaded from the pc into the plc ram or sometimes flash memory..
Before you get started you need to make a list of all your inputs and outputs and then create your self a flow chart to work from before building your ladders
If this system has to be safety rated. That PLC will not cut the mustard I'm afraid.
As has been mentioned, RS232 to USB converters are common an pretty cheap.
GX developer is used to program mitsubishi HMI's (GOTs in mitsubishi language). GX works is for programming the PLC. An no, it's not free.
Hi Rob,
Thanks for the response. It's for a trade show only and will be sat on a bench. No real life safety required at all - just a demo piece.
As mentioned they are not free software.
You can program ladder with GX Developer as well.
Have a look on RS Components for prices.
GX Developer will only program Mitsubishi plc's. It will not program hmi's
Same for Gx Works 2.
The programming cable is called an SC09
They are expensive from RS but Chinese copy's on ebay are about ÂŁ20 and they are usb
Gx developer is no longer up to date. Gx Works 2 covers the latest plcs.
If this brake unit supplies analogue values for temperature and wear etc, you will also need an A/D converter for the plc.
I have been programming plcs, hmi's and scada for 25 years
So anything you want to ask.... Feel free
Reply to PLC help required for beginner in the Talk Electrician area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
Try to use a catenary wire for better support for your outdoor cable. I'd recommend TP-Link ceiling-mounted access points, which are good options...
    • Winner
