plc problem | on ElectriciansForums
Discuss plc problem in the Electrician Talk | All Countries area at ElectriciansForums.net
E
engmnabil
Hiiiiiiiiiiiiiiiiiiiiiiiiii
I have a plc device in my company but one of the outputs become not work and the other outputs work good
you must know that the programed secured i canot change it can i unsecure it?what is the problem?
more information
i have plc device.it was worked in my company from 10 years on a line production for gas tubes. two days ago one of the process that the plc was made not operate and the others operate good
i try to see the program on computer but i cannot because it secured
more information
more information
Normally there are different levels of access to a program depending upon the program.
But basically there are 3 levels the first where you can see what the program is doing but cannot change the program and the second where you can change certain parts of the program eg inputs and outputs and the third is the total writing of the program.
It sounds like you do not have a access code to check anything, if you have a hard copy of the program then check to see if you have an output at the required terminal to operate the necessary process.
OK,
So Mitsubishi are you using GX developer software and a red comms cable ( does it have a 'D' connector or a round connector on the CPU of the PLC?
G
engmnabil, your info given on this problem has been second to none, fantastic, really helpful!
You will no doubt find the failed output to be u/s, goosed, knackered, capput, shagged!
Due to the fact that your evidence has been poor along with your idea of what the fault could be, my crystal ball says to me that the output is probably a relay signalling a solenoid and it's burnt up.
Unfortunately unless you have the software and sc09 lead to access the plc program, plus the competence to make the desired change, which would be to assign a spare output, then there's little chance of you doing anything to resolve it.
Perhaps you should have an automation engineer/systems intergrator come in and correct the problem.
Please feel free to prove me wrong!
Regards
s.f
Reply to plc problem in the Electrician Talk | All Countries area at ElectriciansForums.net
ROBOTS!!!! I have a terrible fear of Skynet.
    • Winner
Concerning isn't it. I fear it's just going to lead to reduction in standards and entry requirements and flood the industry with even more poor...
